Hey I'm about to install the exhaust manifold and the manual says to use loctite 515(gasket maker) on the bolts. I don't have any but was searching around and saw someone say that Seadoo no longer recommends doing this? Would grease and 242 cut it on the bolts ? I have a brand new gasket..
You need something on two off the screws they go into a water jacket. Not sure where you got that info. Follow the manual you can't miss. Permatex makes something with 518 in the part number. Check you're auto parts store.
Ok, trying to mount the alignment tool but when putting the pump bolts back on, they run out of thread before they can tighten down the plate. Just stack washers on the bolts?
Here is OEM for a few bucks more(if you don't make an offer). This guy has 2 so it's a one stop shop. Make an offer, they usually will deal, especially on both. So say 15 each if you buy both and combine the shipping. So you paying the same as aftermarket and getting the good stuff.
Don't like that color? here's OEM black for $17 plus $2.32 shipping from TerriPoppy (same as the covers), again more than one on hand and no BS aftermarket.
Thanks racer, bought the two from Terri. Now to find me a water regulator rebuild kit. My bellow is getting weak where the clip has been poking it. Going to switch to a zip tie this time around probally.
With my TRD waterbox, the stock short exhaust hose is too short. Anyone know the exact size of that thing ? The diagram gives no size .I thought i saw somewhere 1 7/8?
