Looks great! I have never tried any other steering/handlebars on any X4 or seadoo I have owned, but I might have to try it.
10-4, thanks Mikidy.Contact Nick or Jess at Westside Powersports Seadoo as he was having new ones made at one point.
Saw a listing for a battered 95 SP with no trailer, title or functional carb(s)? for $2250 the other day. Glad I found my XP when I did lol.Looks great!
Seadoo’s are the only proven COVID cure. Don’t tell anyone though or the prices will get even higher, lol.
Lookin sharp man, First saw your ski on reddit. Glad to see its coming along so well!Been down for the count with Covid the last week and a half, but took advantage of the warm weather and feeling a bit better this weekend to get everything wrapped up minus reassembling the pump housing:
I decided to go a different route with the bars & ordered a set of KTM 50 mini bars. They look a little more proportionate on the ski and are a lot more comfortable. Thanks to some help by @fatblockabody, I'll be water jetting custom UMHW sponsons in the coming weeks as well as working with a local machine shop to machine custom start/stop & VTS switch housings.
The hump seat I've had stored the last several years is in rough shape. It'll end up getting new seat foam and a Jettrim cover at some point, but I'll be reusing the stock seat for the time being. The Jettrim seat cover going on this ski is identical to the one above, except the rear of the seat will be pink instead of the white seen above.
I was planning on 3D printing a few supports but if you have one available I'd be interested. Shoot me a PM when you get a chance. Thanks!I think I have a few of those rubber gauge supports 293-720-005 if you still need one
Well, it doesn't appear to be the rectifier. With the red wire unplugged, it revved to about 4600 RPM before falling flat on its face. I'm contemplating putting the primer tee on the reserve line for easier starts, but I can't see that as the root cause of the issue.I always put the primer tee on the RES line to avoid any restriction or air leaks on the ON fuel line. For the fittings on the carbs I have always used JB Weld.
The rectifier is very easy to check, just unplug the red wire from the rectifier and see if the ski runs fine.
Did you remove the chokes when you installed the primer? I've never installed primers but perhaps removing the choke might alter the fuel/air misture. Might need more fuel. Just a thought. Good Luck !!
Good to know. I didn't have any issues with it all year last year, but first fire up this year it started once, died, then popped the fuse the next time I tried to fire it. I had originally thought it popped when I reconnected the infogauge, so I put a new fuse in, fired it two or three more times, and it popped again.My 1996 SPI blew the whole MPEM. along with the 5amp fuse. That was the beginning of my delving into the MPEMs. Root cause ended up being the rectifier so do some checks on that. Don't let it keep popping that 5 amp fuse it may get into the MPEM and blow the diode I had to replace. Upon testing the rectifier it was easy to determined it was shorted internally. Good Luck !!
At the time of failure I was riding my ski and having a ball on this twisty river and all of a sudden BAM, dead. Everything.
