Yes Sir, just use two of the nuts from the head and screw them down to lock together and you can use those to back the studs out.Manual said you have to remove the rods/studs before remove the cylinder.
Stick an led light into the rave ports and then take each piston to top dead center. See any light around the piston rings/edges? It looks to me like you have had quite a bit of heat blowing by on those rings at this point.
Yes, the manual mentions this before you commence engine disassembly of the top end.:cheers: It's not coming up and off of there otherwise.Too funny. Just realized that I need to take the whole exhaust out.
Is that some pitting in the cylinder walls? If yes, I blame this on corrosion.
Is there a ridge you can feel at the top where the rings reverse direction? If yes, this represents cylinder wear near the top.
You'll be glad you did this, so far it looks like you caught it just in time. The idea with a top end job is to buy some time and restored performance at a much reduced cost versus a complete rebuild and it's not even an option once something let's loose. Those cylinder pics are enough to show wear to the degree that what you're doing right now is in no way premature at all.
Actually I'm a little surprised at the amount of cylinder wear, I didn't expect this much. Now I feel a need to inspect my piston skirts through the RAVE ports again, last fall they still looked good but it blew 120psi then.
First time I checked my motor the day I bought it, it blew 135psi but I'm not sure how much oil may have been in the cylinders.
So if we can confirm the low end is good enough, I will ship the top end to fullbore on Monday. I may just drive to US and ship it to avoid custom delays.
Is it the plan? If no surprises?
Yes, what we didn't see was deep scarring from a broken ring on the cylinder walls and that's a good thing! I set notifications up to come to my phone so when you get back to working on it tomorrow post and I'll get back with you.
I'm anxious to see what those pistons look like tomorrow.
Do I need to spay some WD40 into those long stubs holes? It seems very tight.
Is it ok to have wd40 into the cylinder and water jackets ?
The amount of wear on the aluminum + silicon alloy piston will be greater than the amount of wear to the cylinder bore, once this wear increases to the point the clearance is increased beyond maximum tolerance the rings are probably quite worn and have lost their tension against the cylinder as well thus the sealing is compromised.
Pitting and scoring of the cylinder walls also contributes to combustion gasses blow-by, causing overheating of the rings and piston, and oil film failure due to heat (oil cokeing/varnish). Excessive piston clearance will allow to piston to turn sideways in the bore (unparallel) and the bottom skirt bangs against the cylinder (piston slap), this action can crack/break the skirt just above the bottom, depending on the profile of the skirt.
There is a good amount of carbon on the piston crown, indicative of overheating in low hour motors. If you decide to remove the pistons then it will be interesting to see the underside of the piston crown to see if there is carbon there also. If you find carbon on the underside of the piston crown, this confirms the pistons were overheating (most likely due to compression loss and excess tolerance).
Also I noticed the squish band of the cylinder head seems to be pitted (a sandblasted look), it seems like this may have occurred due to detonation, (the squish band is the most likely location where detonation occurs).
What I didn't see though, was pitting of the piston crown around the same location as the squish band, so I'm unsure if detonation was actually occurring or if the sandblasted look of the cylinder head squish band is a "factory feature".
Is the pointed area the squish band?
