Bonmotwang
Yesterday I saw the highest speedo reading 38mph with the whole family on board.
I think 518 did its job with the new cone.
I checked the compression today before fogging. 129/130PSI cold start. Then I ran it for 20 seconds. Then checked the compression again, now the head is warm, I got 125/125PSI.
Then I fogged the engine.
The compression on this boat after the rebuild is always like that and run very well. Never seen the magic "135" :-D.
Tested the 3000RPM issue again yesterday. More info: it can run at 3000RPM for 20 minutes or more no problem very stable. It only happens, not always, when increase the speed from idle into 3000 range. And when speed drops, it dropped to idle speed, but I didn't wait long enough to see what happens next. I just pull the throttle back and fast forward to fix it.
I will take the carb off in the winter to take a closer look because this was not there before the carb rebuild.
Is it something to do with the high speed screws? They were 1/4 open before, and I totally closed them after the rebuild.
