Bonmotwang
Yes, you can spray WD-40, there will be no damage.
I suspect the studs were installed using lock-tite red so it may be necessary to heat them using a torch to soften the lock-itte.
I think you should be able to lift the cylinder assembly while the head studs are still installed, I don't understand why seadoo says you cannot..
Ok. Soaked in
