Bonmotwang
Just checked the manual. I thought at the bottom of the bellow it was missing a small spring ring, but no it doesn't have one. is the rubber tight enough to stop the exhaust from leaking out? There is some black exhaust leaking marks around the rave area.
Sent from my iPhone 6 using Tapatalk
Now with clean parts in hand, easier to see how 787 Rave works.
Let me know if I got it right.
The exhaust air gets into the bellow not just through that small air passage, but also the clearance around the shaft. The oring only seals the shaft clearance when the rave wide open.
And if the surfaces around that oring is not smooth, the exhaust air could push through the bellow at high RPM, and cause black marks on the surface of the engine.
Does it make sense?
