They cover the silicone that is covering the screws where they protrude thru the hull from the ride plate.
Baby wipes, seriously? Get some expanding rubber plugs to seal the intakes, smear a dab of grease over the carb bolt holes and use some Castrol Super Clean and hot water or my bilge cleaning formula.
2.5 gallons of the hottest water you can get your hands on, 1/2 cup TSP powder and steal a capful of laundry soap from your wife. Put the bilge drain plug in, hook it up to the Jeep and dump that whole mess in the bilge and go for a drive you remember that ski you looked at when you were here I had just done the motor on? It was ten times worse than your's and that cleaned it right up.
Pto carb is apart
Planning to get an ultra sonic tub.
Looking around for a used one.
Sent from my iPhone 6 using Tapatalk
That is so clean I'd just hit it with some cleaner, a rebuild kit and N/S and be done with it. Pop off test just to be sure. But it probably would be fine.
Toss it in your ultrasonic cleaner, it should lift right off.
Checked again.Dang! 90$ for fuel lines!
Thanks Bob for giving the total length of the fuel lines I will need.
Got the fuel lines: 20' of 1/4" and 5' of 5/16".
$87 in Canada. I bet probably half in the states.
That's just wrong.
I paid 80 cents a foot for line and 25 cents for every stainless clamp. I had to do two Ski's that had not been touched for 13 years. The carbs had never been opened ever.
