Did more checking before going to work: I can feel the grooves by a stick, not deep and color cannot be rubbed off. Also pushed the piston sideways through the spark plug holes, cannot feel any play, so shouldn't be too much wear except the grooves.
Were these Pistons painted white? It does look like paint or thick coating to me. The black coating on the new piston for my 951/947 engine went away in less than 2 hours, which was very thin.
Do I need to open the top to take a look at the cylinders and inspect bottom end?
The compression is 155/155PSI. Same meter showing 125psi on my 951 engine. So the measurement should be correct.
I didn't run hard on Saturday with boys only top speed for a couple of minutes. And that was good 2 minutes, got on the plane right away and very strong pull. But didn't have time to do some long time hard test.
Sent from my iPhone 6 using Tapatalk
