I have a raging case of jock itch. (I hope) but I was out with sis the other day.
Should I go to the clinic, or should I just put Gasoline on my junk?
Doc,
If you go the gasoline route, don't forget... premix with API-TC and not TC-W3 or your junk will seize up! Unless you have an injection system built in that is... Then make sure your tank is full! I suggest the full synthetic unless you are OLD!!! (Then you need at least part mineral oil.. low ass! I mean ASH!!!) And next time... USE PROTECTION!!!!! They sell baggies and rubber bands at the Cum and Go! Hope this helps a newb in the Sis department!
Dont mean to be buttin in on your help thread guys, just thought I could help with this one! I've learned a lot since I've showed up here!
Sink
Wait a minute, you're the Doc., you should be telling us. I think Jake's advise is right on, it doesn't happen very often. Castrol Super Clean is the way to go, they may not have it at your local Walmart so you might need to use Purple Power. Pa always told us that "if Walmart don't have it you don't need it". Pa is a sage of knowledge in a troubled world.
Another tip, when you're through using the Castrol Super Clean on your privates you can use it to clean the bilge of your ski. Also I would not recommend using the Super Clean on any internal parts of your body or not to insert in any orifices of said body, I know from experience.
Lou
DON'T USE PURPLE POWER !
Got it all over my hands one day before reading the instructions. Later that day my skin drew up so tight I couldn't straighten my fingers. If you use it there you may end up an innie instead of an outie........I would suggest shaving then applying icy hot, that's the militarys cure. Just be sure to have your dancing shoe's on and a fan.
Hi guys....
Well, crisso was almost right. It was crabs. So... I shaved a fire break in the pubes... then I set one half on fire... and stabbed those little critters as the ran to the other side. Now I just have to get rid of the other half. (after I clean up the blood, and take care of my burns)
