Do any of guys know what things need to be do for a proper tune up. Id like to check to insure that they all have been done.
I do trust that the mechanic actually did everything.
Any feedback what be helpfull
When someone brings me a 2 stroke jet boat for a tune-up I perform the following, it has to pass a compression test within 90% of specification and I'll work on some that are within 15% with the understanding that the motor is at the end of it's useful service life and needs at least the top end restored to factory specs, I won't touch it again after that unless it's coming apart for an inspection and rebuild.
There's very little reserve horsepower in these boats as compared to ski's running the same power, you need all of it to experience a reasonable level of performance from the boat. The ability to place passengers and tow load on the boat in addition to the much larger wetted surface of the hull really takes it to task.
1. Compression check
2. Ignition check with a Stevens CDI tester
3. Charging system test
4. Rave valve/housing cleaning and repair as needed.
5. Complete disassembly, cleaning and rebuild of the carbs, accelerator and fuel pump with new kits and fuel supply testing for filtration and flow including the operation of the fuel selector valve. Carbs must pass leak and pop off tests before installation and the air box and filter are cleaned.
6. Adjustment of the throttle and the oil injection pump cables
7. Lubrication of the PTO shaft and inspection of the drive and wear ring / impeller condition.
8. Exhaust and all water lines are inspected for leaks.
9. Water test and tune carb adjustments, verify no cavitation issues from leaking seals and make sure the boat runs 100%.
Jet boats more or less are low tech/high performance toys that need everything to be right or the experience is lousy.
