Waterluvr
The oil stainer come as 1 unit i dont have to open it. Is this what you are talking about?
Yep, it's got the hose fittings on each end. ~Lake Effect in town there close to you usually has them in stock.
Sure, in fact of your wanting to just change the impeller might as well order that filter from SBT (pn#36-105) and grab a couple of their neoprene seal rings for the pump shoe you can buy them 3 for one compared to what you'll pay in town for them.
Is neoprene ring seal for pump shoe what im exactly lookin for
Go plug your boat info into SBT's website and have a look around there, they have just about anything your going to need for common parts, cables, seals etc. the customer service is top of the mark, they ship free over 100 bucks. Get as many pump seal gaskets as you think you might need plus one, having a spare gasket and wear ring on hand saves the day when and if you need to change an impeller on short notice ~it happens.One other thing is there a marinia or boat shop near you that you use to pick things up.
I'm not sure which part of the throttle cable you ordered, maybe you ordered both? We discussed the rear section a few months ago but I'm not sure if you ordered both sections or just the rear.
That's the rear section, the piece that contains the TPS. The sections join at the edge of the fuel tank before the cable goes to the helm there is a piece of heat shrink tubing on the cable and under the heat shrink there is a connector there where the two pieces are joined.
7700 RPM, wow! I don't see near that RPM on mine, ~6850 RPM max. I think your tach might be wrong a little but great to hear you got your speed back! Woo-hoo!![]()
Problem FIXED!!!!!! 49 mhp 7700 rpms. I am so f@#king happy its finally over . I guess you guys were right it was the throttle cable.
