The number in the part# on your cap is the impedance ie. TBO 5 EMA. 5 = 5k ohms
http://catalogues.kimpex.com/Snowmobile/2014/en-ca/files/mobile/index.html#85
Thanks do you know a place to order the gaskets online
So your saying that i might not need a new gasket in that case just check it and reseal. Or if i see a paper gasket replacebonmotwang, I see yours has the o-ring type gasket, it also used the paper type with that? There are more than one design, later seadoo used the o-ring gasket for the improved version in addition to the strange rubber flange diaper.
Item 26 is the o-ring gasket but I don't see the paper type being used on this type of manifold? I suppose it's possible to reuse the o-ring but in that case it's not possible for me to have confidence water from the jacket won't leak backward into the cylinder ports?
http://partsfinder.onlinemicrofiche....asp?Type=18&make=seadoojb&a=146&b=4&Action=O
edit: This other drawing shows item #59 as well, the rubber "diaper" as I call it. LOL:
http://partsfinder.onlinemicrofiche....asp?Type=18&make=seadoojb&a=146&b=5&Action=O
What should i use to clean manifold connection area. Or what should i not use. Any degreaser like superclean alright
And yes it does have a rudder gasket that i will change.
Is there anything i should check while i have the muffler off?
Would this be a good time to change trottle cable?
Is there a filter in the little white cylinder on the hose coming from the oil reservoir?
Yes & yes, how's the new tach working have you confirmed the dash gauge yet? Saw your sound system thread, that's going to get you noticed out there![]()
Is there alot to changing the steering cable or is it pretty much straight forward?
