I bet you can get a new seal at CT, if necessary.
It is really really tight. I pressed the shaft through. But really right. Pretty hard to turn by hand.
Rotate the shaft while tapping it from the side with hammer all around 360 degrees.
Must be the thrust washer end, might have to put an internal bevel on that using sandpaper to remove a lip formed by the thrust washer spinning?
I guess the lip formed there crushed your bearing race slightly as you pressed the bearing in.
If you want to keep debris from entering the front bearing then push a cloth rag into the open bore while working on the rear bearing and then turn pump bore dirty end down and push rag out from the seal end and blow with compressed air.
Bronze is soft and will not damage the bearings but sandpaper grit might.
How about the torrington bearing thrust washer surface, is it concave or flat?
I have no problem with the plastic housing, my suspicion is the performance won't be equal (due to water flow capacity difference).
I'm thinking the torrington bearing damage made the bore smaller at the end, so just open up the bore there only and press the bearing race just past the oil inlet notch?
The centrifugal forces are fairly great so I feel like once it spins up the outer race will reshape the bore. The trick is the bearing doesn't seize and spin the outer race in the first few seconds of spinning.
What happens if you spin the shaft with the bearings installed, does the bearing race spin inside the hub? If so, surely the ID of the hub will be made larger?
I'm confident you can restore this pump to it's former glory!![]()
He should send it to you anyway, just get that taper out and send it back to him. Or me, I don't care let's just get it fixed and back on the boat.Then send it to me for proper disposal!![]()
