Sportster-2001-951C-Stock
- The bearing journal of the damaged needle bearing has scratches because the needles were seized and the cage was spinning in the journal.
Edit: Need to find a way to clean the housing, brass particles everywhere.
Are planning to shower with your pump, too?
I guess the needle bearing journal didn't spin inside the housing, so no damage was done to the housing aside from the thrust washer bearing seized and spun the thrust washer.
Are you going to install two new driveshaft bumpers? Did you remove the driveshaft from the PTO already?
