Wow, sounds like an honest guy!
Did he mention if the stock impeller is compatible with the plastic pump? I'm thinking of locating a spare for swap and go.
I will check it out in the morning.
I hammered the bearing out. carefully checked the brass housing. luckily the damage on the housing is not going to affect the performance I think.
- The housing for the thrust bearing got cut in about 0.040", because the metal rollers were broken loose there and pushed into the side wall. This is the most obvious damage.
- The surface where the thrust washer is sitting has some scratches, probably a layer is gone, but evenly, checked with caliper.
- The bearing journal of the damaged needle bearing has scratches because the needles were seized and the cage was spinning in the journal.
- The step on the cone for the O-Ring to sit around got deformed by the heat, it is tapped in now. I put the O-Ring on the cone and cover it on the housing, it is loosing, won't seal for sure.
I put in a set of old thrust washer and thrust bearing, checked the height to the top, all in 0.02mm. (Well, i was looking for 0.02 LoL).
I got a quote for a bearing kit, cone kit and a impeller shaft, $200 shipped, arriving on Thursday.
I hope I can get it back into water soon. But no pressure for this weekend
Edit: Need to find a way to clean the housing, brass particles everywhere.
