USAF_Pride
Is RAVE valves kicking in a normal thing?
That's what makes a SeaDoo a SeaDoo. Normal and as designed!!
backed the throttle down to 5000RPM and rode home 22~25MPH. Sometimes I ski on the trip to or from the island.We ran the boat today less than an hour, the round trip is under 10 miles.
If you ride all day you must pull a skier or riding toy, it's wearing the engine and consuming fuel!![]()
Good, I'm sure you'll let us know what SBT says!![]()
This is nice, keep it at 5000PRM for 10 miles is good enough for me.
If I do long ride, do I need to "rest" the engine on the route?
I guess this is because there is no transmission and all the resistance got put on the cylinder directly? I will try the big Seadoo tube I just got in a few weeks when the water warms up eventually![]()
I think it's dangerous for the engine to run WOT for longer than a short burst like getting on plane, my personal feeling.
I didn't use WOT to get on plane. What I did a few times was have the engine kind of revving around 5000RPM, and the bow comes high above the water, and after a few seconds, it takes off.
That's fine, you don't have to use WOT if you don't want to stress the engine. I do it for the acceleration feeling and confirmation the engine is running properly.
- install the exhaust bracket,
*Yes, the vibration stress on the manifold is too great.
- get the oil pump cable
*Agree, try to confirm front control is not being damaged from the angle(s)
- and confirm the oil is going in
*I think you did this, if it's not going in the engine would no longer run now.
- change the oil to the correct type. (I was trying to take some oil out and show you, but somehow I cannot insert my pipe into the tank from the outside port).
*I disconnected the oil line at output end of oil strainer and placed it in a bucket to drain the tank. Then I confirmed the strainer had no debris inside and poured some fresh good oil through the tank to flush the bad oil through. I was careful not to allow air bubbles to enter into the tube going from the strainer to the oil pump, while holding the tube from the tank high, I refilled the tank with good oil and held the outlet tube so bubbles would not form while reconnecting it to the oil pump tube. No air bubbles were remaining to cause possible pump malfunction. This is a bit of a short cut I took, b/c the correct way is to remove the oil tank and clean all traces of the old oil and to replace the oil strainer.
- the fuel input pipe into the carbs is already black one. Do I need to change the other grey pipes?
*This is a good idea at some point, especially if you need to rebuild the carbs this should be done at the same time. If your fuel does not contain ethanol that damages the gray tubing then it's less of a problem. So if your engine runs out of fuel during anytime then the fuel filters inside the carbs may be plugged with gum from the damaged gray tubing. Fortunately most of the problem doesn't exist b/c the factory used the black line to feed fuel but still they used some gray line that can cause fuel flow problems by clogging the tiny filters inside the carbs. Thus the general answer is to replace the gray lines before engine damage is caused by fuel starvation, and may as well rebuild the carbs at that time. The normal black tubing is usually too thick in the walls to fit onto the PTO carb barb fitting so when you obtain this tubing I think you will find it's necessary to use a thinner wall stuff that's transparent, and isn't laminated with woven nylon.
Do you agree with the list or something else to add?
I can add to your list extensively, probably. But I think you have the important items covered.
Just to confirm the oil squirting process one more time: after pull the boat out of the water, take off the air silencer, start the engine and at the same time squirt oil into both carb openings, about 10ml each?
then shut off the engine?
* I squirt the oil into the carbs and replace the air silencer before restarting the engine to blow out the water. If I see a puff of smoke then, I'm happy. Too much oil will short the plugs gap, so always have a good set on hand, sometimes I use too much oil and this happens so I wash the plugs using a can of carb cleaner and put them back in. The plugs in my motor currently came from my first Seadoo over a decade ago, and I have two spare fresh sets already gaped waiting in the helm gauge compartment.
General rule of thumb is to replace plugs first, if any running problems occur. Always throw away any plug that came from a seized or damaged motor, don't reuse them b/c there is aluminum contamination in them.
You can tell which plug is not firing by feeling the temperature of the plug, it should be warm.
A plug works like an avalanch zener diode, the voltage rises to a point the spark jumps the gap under the conditions present. More compression and pressure in the cylinder requires a higher voltage to jump the gap, in air outside the cylinder it's easy for the spark to jump the gap, so it makes the plug look good sometimes when it really isn't good. Any contamination on the plug electrodes can bleed the voltage off so the plug can't produce a spark, such as a heavy drop of oil in the spark gap and coating the center electrode.
So yes, it's possible to have a slug of oil from the crankcase short out a plug, but often it's easily washed away using solvent and once the plug electrodes reach operating temp they should begin self-cleaning and become cardboard brown if the carbs mixture isn't too rich with fuel.
This is the best one of the month :lol:
There are many question on the net about how to confirm the oil injection is working.
The best answer is here: "Hey run you engine at 5000RPM for about 5 minutes, then you know" :lol:
Just spray some fogging oil in there when you are done using it. Not heavy enough to foul the plugs, but a enough to put a coating on.We are into raining season now. Is it a good idea to start engine for 15 seconds every 2 or 3 days?
You should fog when you won't use the boat for more than a few days, to avoid cylinder sleeve corrosion. If you didn't do this the through the carbs and run the oil in you can remove the plugs and spray some oil into the cylinders or pour a small bit in, enough to run off the piston crowns and wet the cylinder sleeves (more than 5 drops! :O) and rotate by starter or rotate by hand to distribute it. If you put too much in, rotating by starter will blow out the excess from the plug holes.
Always ground plug wires when rotating by starter.
I need to find a bimini top like yours, the sun gets too hot! BTW, my speed numbers posted earlier exclude bimini top wind resistance, of course. The bimini probably makes the Sportster into a good sale bote?
Yes, I will do the syringe to do 20mL per hole. Is 20mL (0.68oz) enough per cylinder?
I guess he took totally opposite way from the sexy ones. :-D
I noticed that the engine doesn't like raining/foggy days. Yesterday I tried a few times and pulling the choke, then started the engine in my garage (yes, with garage doors wide open and a fan blowing at the boat). So the idle speed needs to re-adjust during those high moisture days in the water? And always good idea to have the boat idling for 5-10 minutes at the port before go into the lake?
And yes, a volume of 1/2 oz (~20ml?) should be enough, you can judge this by the amount of oil slung from the plug holes by cranking with the starter. If most of this comes out, then it was maybe more than necessary.
There needs to be enough oil poured in to run off the piston crown and wet the cylinder sleeve, so as you turn the engine the sleeve receives a light coating of protective oil from top to bottom. This will help to prevent moisture corrosion of the cylinder sleeves, b/c micro-pitting from rust on the sleeve surfaces will interfere with piston ring sealing and can be the cause of low compression. The oil also helps to fill the micro pits thus improves ring sealing, so some oil film on the cylinder sleeve is necessary in many ways.
Nobody ever broke a motor by using too much oil, but it's wasteful and messy to use too much.
120/110 is the number after sitting for a couple of days and cold. I will do a test with hose on it and run it for a couple of minutes. It was 60/90 after the winter sitting.
I do have an air compressor, but I doubt the reading on that is accurate. :-D
But I am ready to do more work on engines if the engine sounds overall healthy. Do you think it is there yet?
