Well, I have been working since my last post, so havent had time to do much of anything. I did make it home and found that my XP does have the grey fuel lines. I plan to change them all out (After I get the beast running) but I am hearing there is a temp fix by changing out some of the line near the fuel selector valve, and also near the carbs? Is this worth while? As my reciept states my carbs were both rebuilt/cleaned, I dont want to get them plugged up! What is this green goo you speak of?! I already bought about 25 clamps, but still need to get the 21' of 1/4 fuel line to do the job. Is this something that is known on ALL Sea Doo's or just the XP?
I installed the OEM starter that I paid $90.00 to have rebuilt, and found it was a botched job. Definitely a bummer for me as it took quite a while to get the thing in there and tightened down. I am a bit anal about my work. I took it back out, and just picked it up yesterday from the guys "Second Attempt" and I told him if it doesnt work, I will require my money back and will spend it on an after market starter that should last a year anyways! Should I use Blue Locktite on the install bolts or just crank it down without?
I was looking at a 1995 SP and found that my XP has some things missing that (If I can get it running) I would like to obtain. The front of my XP does not have the "drop in" box that is for storage, nor does it have the tool kit or fire extinguisher tubes. I was wondering where the fire extinquisher was to do. Surely it wasnt to bounce around at the bottom of the hull!!! I also noticed that under my seat, I do not have Air Baffle or tube that comes out near the back where the battery is. Or is it supposed to have one? I am learning every day!
Over the weekend I hope to get the starter back in there for the 2'nd time and hope it will crank this time. If so, I can work on the no spark issue. Maybe it will mysteriously have gone away with the rebuilt starter installed?! One can hope!
Do I need to change the oil in the back cone shaped thing aft of the jet prop? If so, what type and weight should I use?
Thanks, Hope to be on the water soon, but know I still have a bit to do yet.
