I got them to 250, but that's too much imo.It's just a water injection module. There is probably a regular Micro Touch WIM(water injection module) under that pretty billet case. Mel Miller used it to kick on electric fuel pumps to help feed big bore XPL race skis. It reads the rpm via a wire that wraps around a plug wire and then kicks 12v on and off at the rpm point that you set. He has listed this a couple times before and found no takers. Somebody would pop on it if he dropped it to $200 but he appears to be holding out and playing a long game lol.
[MENTION=33499]WhiskeyD[/MENTION]
You got that x4 that was LOADED out of Tifton?
95 XP800!!!
Keep the 2 strokes alive!
Got it! It's in much worse condition than I thought it would be though. What all information did you get out of the guy? I felt like he was withholding information. He said he has had it since 2001 but couldn't tell me a lot about it which I found very odd. He said he rebuilt the entire motor but I'm thinking he has just done multiple top ends. He said he kept burning up the rear piston. The UMI is shot. The stem has a ton of play in it, I'm guessing from worn out bearings? No title either, he said Georgia doesn't issue PWC tittles. I'm going to start tearing into it this week and I'll see what all is going on.
That is correct WhiskeyD no title in GA, however to register it you need to have a bill of sale from the last person to have it registered.
[MENTION=33499]WhiskeyD[/MENTION] I got the exact same info out of him that you did. He "acted" like he did not know much about the ski, but I'm not sure. The pipe, carbs, waterbox, and nozzles look solid though. You plan on keeping the seat?
You got some other carbs as well?
Nice Pickup Whiskey!
Thanks!Its a self resetting fuse. Prob tried to use it for the VTS. The bracket is a home made throttle/choke/oil cable bracket.
I really want Novis so we'll see if I can find some for a decent price before summer.
The guy won't disassemble and take pics of the internals I saw them the same day they were listed and messaged him. They are 46mm I plan to bid on them a tad
