How's it running doomann?
96 XP800!
Keep the 2 strokes alive!
65 is fine. I can turn hard WOT at that speed . 68 to 70 range it chine walks and wont set up for hard corners untill you scrub speed. My Xpl could turn hard at 69 mph. No throttle burp. On crank shafts.... dont spin these mtrs beyond 7k rpm and they live. Failures at 7200 rpm are bad. Failures at 7500 rpm are mutually exclusive to buying a new Tesla.How is the stability of a 951 x4 at 65mph? Also any info on possible hour ratings for a 951 with a hot rods crank? Or even wsm crank?
Total weight of 951 over 787 is about 25 lbs. 100 vs 125) Interesting note the stock 951 pipe alone weighs a mamouth 20 lbs of entire engine weight. I suspect aftermarket pipes weigh 5 or 6lbs. Fitment is issue. Stock OEM is built to fit. Does it lean a little to one side? Yes. Undetectable riding it. What ever conversion weight gains, easy to loose in other areas.. battery...minus 10lbs.. Bottom line on 951 x4 conversion... you want race boat fast on a budget? Throw 787 in the trashI'm curious how the 951x4 jumps... Everyone says the extra weight of the 951 makes the ski lean to the left or right. Does this throw off the balance of the ski in the air?? I love how balanced my 787 skis are in the air
Seadoodoc, your running an oem black exhaust pipe setup on your conversion, correct? I decided to forgo the white pipe install for sake of riding this season and requires lest clearancing of the hull. The white pipe is just too darn snug at the moment.Total weight of 951 over 787 is about 25 lbs. 100 vs 125) Interesting note the stock 951 pipe alone weighs a mamouth 20 lbs of entire engine weight. I suspect aftermarket pipes weigh 5 or 6lbs. Fitment is issue. Stock OEM is built to fit. Does it lean a little to one side? Yes. Undetectable riding it. What ever conversion weight gains, easy to loose in other areas.. battery...minus 10lbs.. Bottom line on 951 x4 conversion... you want race boat fast on a budget? Throw 787 in the trash
Sent from my SM-G920V using Tapatalk
We come from opposite ends of Country Nick! Literally. You are just now tinkering with motors we perfected in 2005 making 200 hp at 7500 rpm. Here,is,a summary. If your sloppy at attention detail and assembly , stick with 657x , 717 , 787 or whatever lawnmower engine your building. Start spinning twin 3 inch pistons @1000 cc hard and your margain of error goes away .. morale of story is stay within knowledge and capabilities. And dooooo not ever jump start your SD !I don't want to start a shit storm but here's my opinion on the 951. Under engineered. Now with that said, if you can keep water out of it and properly build it and maintain it, they can last a long time.
I have heard that a while back hot rods got bought out and then started having them built overseas...and that it's on the level of a SBT or wsm equivalent these days. Way back when... They were awesome. Now... Not so. I personally had a 951 here with a new hotrods crank that came from ses with a boat a friend bought. It literally lasted 10 hours before it locked up, broke a rod, and destroyed everything.
To ses credit, he did take care of it including the cases. He tried to blame it on lack of oil, which we confirmed was not the case. Not really sure how that it is even possible seeing as the piston hardly had a scratch on it.
I think the only way to go is oem crank on a 951, oem fully if the budget permits. Then make dang sure there is leakage from the pipe. Use the diaper, use the deflectors, I think the old mani and paper gasket are better.
In closing if you do this conversion, do not just buy a used 951 and drop it in. Rebuild it top to bottom.
Same,cost . Less rotating parts.Money is something to consider too, what does it cost to properly build a 951, and what/how often must me maintained?
Sent from my SCH-I545 using Tapatalk
Customer once came into my stereo shop and argued how much better vinyl records are than CD's . Years later he is back arguing how much better CD's are over Mp3 files. Im expecting any time he figures out that FLAC ultra high resolution files are the new generation. So Nick... within that intellectual evolutionary chart relative to watercraft, where do u stand ?. Vinyl records, 8 track.... cassette, CD.???. running out of crayons and napkins to explain further options. I must be dense trying to explain. 951 mtr is a dream until you meet 4Tec ..carry on Minnetonka with your minnie mouse mtr dreamsSee the problem you have Brian is most people do not have the superior/expert/guru level of knowledge that you have accumulated over your years of racing. Also most engine builders do not give anywhere close to a level of detail that you seem to have as far as margin of error. Although you have had that 951 apart a few times this summer....some of which was your sons error...but still. I know that wasnt the only issue this summer.
Many people never even take a seat off their machine. They expect it to run a long time with minimal effort. The 951 to many is not that motor.
Again....as we have talked about before...my opinions take in mind the average weekend warrior....not YOU.
You can keep your clapped out 951 Ill stick to my lawnmower engines....dick.
Send me your mtr.. I will assemble free to race spec .. no charge. Just to prove,a point.Sad to hear about hot rods, I was hoping they were the answer to my 787 eating cranks left n right. And I too conformed that it's getting oil.
