Perfect donor boat. And you have all 787 stuff left to liquidate. Correct Matt, 787 runs about 18 degree final timing, vs 951 at 15 degree range. $300 MSD Enhancer turns the 951 into race boat status ( pump gas), with knowledge of dip switch settings.![]()
It's like putting a 600 hp motor into a car with a transmission that was only designed to utilize 200 hp. You're not taking advantage of being able to turn the bigger pump.Never got an answer on the pump swap, is it absolutely necessary or is is something I could do in stages like get it running first then swap it out later?
I'm actually working on a product that will make x4 951 conversions a straight bolt in process. And are you asking about using a stock 155mm pump or a stock 140mm pump? If your asking about the 155mm yes you can. Just elongate the bottom holes on the pump to fit the x4 stud pattern.Oh sure, I understand and planned on doing it, I just was wondering if I could temporarily get by with the stocker..
I'm working with a machine shop right now on the pump adapter and crossbar mounts. Once the prototypes are done I get them off to the patent lawyers and then on to mass production. It probably won't be till winter or early next year.I'd be interested in the conversion product. Gotta make sure the 951 engine I have is good first though. How far off are you from making it a reality?
That's why you get a full donor then you have the 155mm pump to get by on.Oh sure, I understand and planned on doing it, I just was wondering if I could temporarily get by with the stocker..
It helps a lot when your business partner's wife is an attorney lolWow, I can't imagine selling enough to recoup the cost of the patent process if you're using an attorney. I'm sure you have experience doing this and know much more than me though!
