Whiplash
Are you planning on doing any racing? For fun?
The engine needs to be 100% to even consider any power mods so I'm not going to even talk about that.
As for handling, get some 3 degree trim tabs, worx or JD #6 grate, and a good set of sponsons. Thing will turn on a dime. Then you can think about maybe a swirl impeller for bottom end and maybe a steering system which does wonders to the feel depending on who you ask. Obvious mods like mats and a sticky seat cover can be done relatively easily. If you REALLY want to get serious have your hull trued and blueprinted. It actually does make a difference but now we are getting into actual racing mods.
Some of the mods mentioned can be tweaked for the conditions you ride in. Flat vs rough water, etc.
Cool, so I already have the Beach House sponsons, I would love the steering but I can't believe how much it is! I'm thinking the JD grate and maybe do up the carbs then tune it real nice. I ordered TTO tach and under plug temp gauge, that should allow me to get it dialed pretty good. I figure remove the chokes, and install a primer kit and the ocean pro flame arrestors I got with the boat. What do you think? I figure I better get it running its best stock before putting much on it. The Engine seems real solid, 150# on both cylinders checked cold. I think it'll take a little bit of modding. If I get it running good and want more I was thinking a good but mild pipe would be a Rossier, I found one I think I can get pretty cheap.. What do you think?
