Here is a good, not to expensive, sorta needed maintance that should be done, possible every couple of years, is changing your fuel filters -- (2 strainers ) .... IN tank filters, just by removing your fuel pump assy, by removing your glove box compartment (4 retainers) comes right out, and there is fuel pump module, remove all retaining nuts, main fuel line, vent line, and wiring connector, then remove pump assy,View attachment 17179View attachment 17180 and take off bottom plate, then you have 2 fuel stainers (they are called) -- (advanced auto parts sells them ) 1 - part # fs242 -- approx 15.00 - 2 - part # fs220 -- approx 10.00 ---- also, if you want to change the bosch fuel pump at this point, they also have the original bosch fuel pump and part # is 20770241 -- approx price is 93.00, and then, take and remove all the fuel in tank, wipe clean with a shop towel, and re-assemble --
**** this is our fuel system repairs (along with 2 fuel injectors) , there is no problems with gray fuel lines, and carb overhauls, etc ****
and DONT put any fuel inj cleaner, etc in the fuel, (just clean 87 octane is sufficient)
yes the gsx and gtx are the same pumps as well as the entire fuel system
yes the one posted by griz will work in a gsx, i have a 99 gsx rfi tooregulator should be fine, they are very easy to replace without pulling anything apart so i wouldn't worry about it. be sure to replace both filter screens while you're at it. just take your time while replacing the pump and really observe as i made a very stupid mistake lol! not a hard job but i wasnt paying attention and make one mistake by putting the metal tube from pump to regulator backwards causing pressure loss.
ask all the questions you want, that's what we're here for,
I have no idea how long they last but if it were me having it already apart, i would replace it and get it over with. one less thing to think about. in a car, pumps usually last around 100k miles but seadoos take lots of punishment.
I have a 1998 gtx rfi with 351 hrs I traded for last week, had it on the water yesterday and seems to run and handle great, the previous owner had it for 3 years and says as far as he knows, nothing at all has been done to the ski. Any suggestions where to start with a Maintance aspect. I know very little about these things, can imagine plugs to start for sure. And he did say all he has ever used is the synthetic oil, and even gave me a quart. So that's a good thing right. Any help would be great. And thanks
