PGHMAN
Hi Jeff,
I completed the rebuild and install of my 98 RFI last week. OnFriday I did a hose test and it fired up on the 1st push of the Start button. I ran it breifly to inspect the gaskets, etc. - looked fine. Took it to the lake on Saturday and folllowing your break-in procedure above, I ran at 20% throttle varying down for about 25 minutes (ran well) then headed to the dock for a 30 minute break and inspection.
I went back out to increase the throttle rate to 50% and it ran well for about 15 minutes and began to bog down and I would not accept throttle. I limped to shore and decided to pack up due to time.
I plan to test the rectifier tomorrow - I believe it's the original. To test, I plan to attach hose and rev engine to 3500 rpm and test the battery to see if it jumps above 15 volts. Am I on the right track?
PS - in addition to the rebuild I drained the fuel, pulled and inspected the fuel pump, replaced fuel injectors with new ones fron Five O.
Thanks, ROb
Thanks, ROb
