Ran perfect for 40 minutes. Parked to let it cool off (part of break-in process), then we will go out for a few more minutes![]()
I wouldn't touch the carbs until your through the pre-mix and the next tank, just keep checking the plugs. If you have 30:1 pre-mix in there that is way fat. 40 or 50:1 for the first tank is good to go. The pre-mix at 30:1 is probably causing your loading up.
Careful with that trailer... I SOMEHOW bent the SH!T out of mine, and I"m pretty sure I did it while towing. There were no dents from someone hitting me or anything, but when I look down the center of the trailer, the tongue is aimed about a foot to the right... It's the damnest thing. I suspect it might have happened when I was towing during rush hour and had to make quick turns from stop to make it into traffic. Apparently these trailers aren't THAT tough, and mine is the heavier galvenized one. Didn't know my 4-banger Jetta had that much torque... Not sure how I'm going to set it true, but once I do, I'm welding two heavy plates at that area where the beams join. Good luck!
Maybe someone hit it in the parking lot while it was parked last time you had the boat out?
As far as colors go, Krylon fusion the hood either satin black or yellow ( Krylon Fusion ) This stuff is awesome. The for the seats yellow and black or yellow and gray. I'm heavy on the yellow, and the gray, LOL. The tape off the rub rail and Fusion Satin black it. It works awesome. If you check out my HX build thread all the purple trim was removed and painted with the satin fusion then I riveted it back on. I took the front bumper and twisted it 180 deg. and it didn't crack or anything. If you scratch back through you can touch it back up.
I dig turfing the rub rails. Looks pretty cool if done right.
AWESOME day at the lake. After I fried the engine in the Challenger a few weeks ago and had to send it back to SES to be rebuilt again, the investment was getting some criticism. Who knows, it may still turn out to be a bust, but today.... today it ran like a champ. Almost 8 hours on the fresh rebuild and it purred like an angry kitten the whole time. Running it really heavy on 2 stroke oil for the break in period. So it has been smoking like a rebellious teenager. First tank of gas is nearly empty (burned probably 23 gallons so far). Looking forward to seeing how much less it smokes on plain gas.
Actually pulled the kids on the tube several times today. The youngest (8) LOVED it and was directing me to go faster and look for wake. The oldest (10) was not quite as aggressive, but close (he claimed to have blacked out for 30 seconds after getting big air on some wake). The middle one (9) would protest if I got up to planing speed and freaked if there was any wake.
With almost 10 hours successful hours on the engine since the last rebuild, I moved on to a more "cosmetic" issue...
I removed the old radio cover and put in a new cover, radio, and speakers.
I swear, the prior owner had a thing for using the wrong materials...
I mentioned a few months ago that he had installed a new bilge pump float switch, and joined the wires with wire nuts.
He also had installed speakers using regular screws. I was only able to get 2 of the 8 screws out, the others were so rusted that the heads stripped or broke off. I thought that swapping the old speakers for new one's would be the easy part of this job, taking maybe 10 minutes. It ended up taking MUCH longer as I had to drill the heads off of half of the screws. Given that I had ordered a "Marine" radio and speakers kit, I was shocked to find non-stainless screws in the kit. My stash of stainless screws is on the big boat, so I had to swallow my pride and temporarily use the stock screws to hold the speakers in place. I'll swap them for stainless screws later this week when we get to the lake.
Also found that the "brass" screws that I used to hold the new battery tray down are rusting.
Something tells me that they aren't really brass. Guess I'll be swapping those also. :facepalm:
I've got 3 other things on my list, although I likely won't get them all done tonight (leaving for the lake after work tomorrow):
-install LED lights on transom, in engine bay, and in the passenger area.
-install a fishfinder that I had laying around... the thing is HUGE and NOT a good fit for the Challenger... but it is paid for and on-hand. I'm going to mount it to the white cup holder insert at the helm so that I can easily remove it by taking out the cup holder (a $2.50 item at walmart). This unit has a transom mount transducer and lists 3 options for mounting: transom on a flat, transom on an angle (for high speed), or inside the hull. I know that the inside the hull mount will degrade performance, but I used silicone to glue it to the floor of the ski locker just below the driver's feet. If it works well enough, then I'll leave it there. If not, I'll look at other options.
-Install a 2" voltage gauge. I've got the hole saw and installation should be pretty straight forward... just can't decide where I want to put it. Most likely options are the center of the instrument cluster above the steering wheel and to the right of the steering wheel, in between the wheel and the cup holder.
All of these electrical installations, combined with my faulty fuse block in front of the helm, have me agreeing with PR that I need to install positive and negative bus bars behind the helm. The way the wiring is evolving now is looking rather Bubba-ish, and that drives me nuts.uke:
ahhhhh! late for a dr appointment, gotta go!
Did you take the ski locker sock off?
Um....
what is the Ski Locker Sock?:blush:
Crap...I bet yours does not have it. My 1800 has a black fabric sock on the forward part of the center floor locker that extends the ski locker to accommodate longer water skis. I took mine off and mounted my transducer there below on the floor. Then reattached the sock.
