Guest_User
ok, if your oil pump cable and oil pump adjustments are correct, then you are receiving the necc oil for that set up.
as long as you don`t see any air bubbles or leaks in the system you should be GTG.
and for rule of thumb for anyone premixing...
the ratio is 40:1
def read up on the RAVE`s, it can drive you nuts troubleshooting if you don`t check that they are functioning properly and it can caost rpm`s up top, and performance loss as well...
you should feel an abrupt change is acceleration when those guillotines pop open, like someone kicked it in the azz!...lol...
I believe I don`t have my red adjusters screw all the way down, I think I have them at 1 turn out. there was a service bulletin a few years ago on the correct adjustment for these boats...
you`ll have to poke around the forum, or maybe Doc knows and he can just spit out the info...
Mine open between 5.5-6k rpms, you`ll feel the transition when you speed up and slow down, you would also feel a surge feeling if you are in the transition spot where the valve opens and closes again, just avoid that, either run with them open or less rpms when cruising when they are closed...
the ratio is 40:1
