Found a couple more parts that are missing. Luckily I have a ski I can borrow the parts from.
Exhaust mount
Throttle bracket
The oil pump was missing the bracket for the cable
This did not have the bracket.
When I took off the cover of the green one we noticed the spring looked too long, so we looked at 3 other pumps and all had shorter springs. So we switched that out too.
The long spring was not seating right and if you tried to put the cover back on it was way too hard to tighen down.
We aligned the motor, which we had to take off the pump and then the carrier bearing and mount. Plus remove the 2 drive shafts.
We received this with 0 shims. The front mount needed a shim and the pump also needed a few shims.
We set the oil pump cable
At first it started out like this
A little adjustment but still not there.
3rd times the charm, looks perfect to me
So we hooked up all the fuel lines, positive cable, negative cable, pulse lines for the raves and carbs, put the pump and everything between the motor and pump back together.
Almost done, just need to hook up the exhaust, airbox and put in the oil tank. Then just go through everything and tidy up the lines.
The raves were not machined down. The bore was .50 over and one rave was stock and the other someone hacked up pretty bad. So the owner is having them trimmed down. He is going to trim down .25 off.
We spent alot of extra time just cleaning things that should have never been there. Alot of scraping and scotchbriting, so far we have about 50 hours into this between the 2 of us and we still have a full day to go, but everything has been gone through the right way. We are just hoping that all the electronics are good to go.
With all the time he put into the bodywork we wanted the inside to have the same attention.
