NIL8er
ordered them : )So then those links I posted would work since you have standard bores. Mine are easy to read because they're brand new still in the box.
in some states they will sell retail.^^^^^^Gotcha, it read like YOU bought it direct from WSM.
the oem counterbalance shaft bearing is on back order, anyone got a new 6304E lying around. Ball Bearing 6304E
290932095 420932095
The following are SKF bearings, the same mfg that seadoo gets their from--no China crap bearings. Most SKF's are Germany, Spain, Argentina. I do have a full set, but will be holding on to them, I bought the extras as a mistake. Have you tried you local bearings and drive place? My guys are usually just around dealer price on the bearings but if they don't have it, I can have it the next day or the day after at no extra charge. If I have time, I just get surplus off Ebay. Just ordered some other SKF's for my neighbors pool pump---ditching the cheap China bearings that lasted them 3 measly seasons in a brand new pump, I won't touch this pump for years now.
Front bearing with High Temp grease---I just paid $20 for a pair shipped
http://www.ebay.com/itm/SKF-6304-2R...620?pt=LH_DefaultDomain_0&hash=item4191504704
Rear bearing I just paid $21.98 for a pair shipped
http://www.ebay.com/itm/NEW-SKF-ROL...789?pt=LH_DefaultDomain_0&hash=item20f71ae2ad
I appreciate it. But why the smart ass remarks. just wanted to make sure i wasnt missing something. Not questioning your expertise.
so bottom line is thatll work?
Yep, you can look in my threads and see the case fill mod. Google search for seadoo 787 case fill mod racerxxx.
Just use hd-30 sae oil. They used to use xps2 2 stoke oil
never mind i see it now, and your right gonna do the sealed one too.Push it on till it bottoms out. You better do the sealed one too, that's the one that will go bang.
No, I just wanted to blow $42 on paper weights. Yeah they'll work, if you don't want to use them you won't hurt my feelings. If you want to check up on them, again, go hit your local bearing house.
I just took this pic, I have them in hand and they're going on a cb shaft here in the next week. I already have the JEM in my 96 engine. If you look at my build threads, I typically don't cheap out on crap. I'm the guy who doesn't want problems on the water and I don't want to ride with my shoulders scrunched in the air wondering when it's gonna grenade and if I'm swimming home.
The front by the mag housing get the sealed
I believe it states it in the manual. I never disassemble anything until I get the replacement parts, or I take a pic with my phone.
