Ok, so then IF they are standard bore pistons you will need the standard rings. On top of the pistons (provided they are the origianl ones) they should be stamped ELKO and a number that is 81.89. If so you need the 82mm rings 290815080 and 290815100. You will need 2 of each they are sold individually. Again you must confirm what pistons are on there, you never know who was in there before you.
Here is a guy selling 2. He has make offer, hint hint.They're normally $23 each at teh dealer.
http://www.ebay.com/itm/Genuine-Sea...100-/161444602156?hash=item2596d9212c&vxp=mtr
Here is an OEM "equivalent", these are probably RIK rings. The OEM rings are usually $43 a pop at the dealer
http://www.ebay.com/itm/NEW-PISTON-...0CC-/301338025467?hash=item4629255dfb&vxp=mtr
