Hi,,wondering if any body has problem with the PTO side piston getting scorded after running for 10 or 15 minutes. long story-- I bought this from a flipper-Jimmy Roberts from Wisc, beware of this guy and his wife on marketplace ,,he claimed he had recently rebuilt the motor and gave me a short warranty. back in 2021. him and him wife took the Facebook page down after I tried calling him. so I took it to EJR in Belivede Il. he said I needed to rebuild top and bottom. so I said go ahead ,that I just bought it and what else can I do, he took all summer , gave it back in Oct and said I ll have to bring it back for him to dial in the EMC for codes. I took it back the next spring, it then took him all summer again and said it was it needed a fuel pump, , he did it, for another 500.00. once again I got it back in Oct again and couldn't ride it, too cold again, then this May I tried to start it on a hose before I took it to the river, again, it wouldn't start good and if it did , would dye out in a few seconds, I called EJR, he said to bring it back again to see what's going on,, EJR called me again and said the back piston[PTO] side is 'galled' and needs another set of Wazzen pistons and clean cylinders AGAIN! he told me he sees oil in the cylinders and even added some Klotz oil to fuel. he said he's a engine builder and says everything he did is by the book.. he said he would not warranty or change the pistons again if it happens again and said I need to part it out with the rebuilt motor or buy all new electrical harness, ecm, sensors,ect.... and its an expensive electrical problem that's causing piston overheating and scoring.. so I wanted another option,cuz this sounds crazy to me. EJR said he went through all and cleaned fuel injectors, fuel lines, it has fuel and air pressure.. he says it has to be electrical problem. I then took it to another Sea-Doo pwc mechanic . Fox valley power sports in Lake in hills Il. he said it looks good/ok visually but noticed the fuel pump was a cheaper one and probably going out with low fuel pressure to the motor. so he changed the fuel pump again with a better one[like oem one? he said] another 500.00 bucks, they said this should do it, so he and I took it to the Fox, put it in the water, it took off about a minute and dyed out again. we got it idled back to the trailer. Fox Valley power sports , says he thinks the pistons and cylinders are not bored to proper specs with these new pistons.i don't know who to believe, and I'm over 6500.00 in a 3000.00 sea Doo. this has been going on from the day I back 3 years ago and have never riden it ...now way over budget and I cant spend anymore money on it, its a shame its in pretty good condition, anybody have any idea what it can be , ? or what I can try ..thanks for any thing that may help..
