i think if i was going to that level of effort i'd have to do black gel.
actually, depending on how much you have i could use some white gelcoat. I need to re-gel the fiberglass bow cover for the speedster. Maybe we can figure something out when you come pick up those engines.
I could also prep that one for you and ship it if u need.
That gel coat is extra weightI do have a question for you guys. the inside of the hull cleaned up ok. I know i can get it better but i was thinking of doing the bottom in white gel coat. i have 1/2 gal left from the boat. thought about scuffing it up and rolling on a little coat....thoughts on this?
that gel coat is extra weight
What ever you need to help you keep up with the saltpigstrue but im only 165lbs so im sure that i can take a lb for it to look nice ha
what ever you need to help you keep up with the saltpigs
I have the candoo in my spx, works really well and super easy to install.
I think there is a tradeoff for the lightened flywheel and pto. You gain acceleration, but lose speed more quickly in turns and chop since there is less rotating mass to keep revs up.
What are going to use to get to the larger hose? Just a plastic barb?View attachment 38676 this is what I'm going to use
