Bonmotwang
To remove impeller from impeller shaft, you're going to need the spline tool and a bench vice, torque wrench too to reinstall to 85ftlbs. Use anit-seize on the impeller threads. This could be hard to do if the impeller is seized to the impeller shaft, some heat may be necessary to soften the lock-tite, and the heat could damage the lip seal.
Remove the stainless clamps with pliers, tear 'em off. Careful not to rip boot though, then use nylon plastic tie-wraps as clamps to reinstall.
Thanks. i am reading the manual for the bearing and seal removal. a special tool is mentioned again: 295000144 bearing/seal remover tool.
Do I need that too or some tricks could be used?
