Bonmotwang
You're moving right along!To remove driveshaft, it would probably be easier to remount the pump temporarily because the stainless steel seal carrier ring that seals against the carbon seal must be pushed aftward against the pump in order to remove it's retaining c-clip from it's groove in the drive shaft. The pump will hold the shaft and help to keep the shaft from sliding aftward as you push the stainless ring to reveal the c-clip.
c-clip to remove from groove in drive shaft is item #9 in this drawing, the SS seal carrier ring you need to push aftward to expose the c-clip is item #8, carbon seal is #14
http://fiche.seadoowarehouse.com/se...46&b=12&c=0&d=-PROPULSION-SYSTEM---DRIVESHAFT
You don't need the blue drive shaft protector, if it breaks and comes apart it will jam up inside the impeller housing and trash the wear ring. Mine is already broken off and I'm not going to replace it when I rebuild my pump.
Thanks. I will try this procedure tonight. By looking at the drawing, when I take out the drive shaft are part #3 all the way to #10 and #14 going to just fall off?
