Bonmotwang
putting oil in the cylinder or on the piston is skewing your comp test numbers!!!
you are filling the cross hatch lines with oil creating more of a complete seal... no matter how many times you crank it after wards...
Cold engine, throttle open fully, crank for 5 revolutions and look at the gauge... that is your number...
I don`t recommend doing a hot test at all... I never pull a plug from a hot aluminum head ever, regardless of what you read or hear... always try and do what you need to do to a cool engine...
spark plug torque values are different from ambient temps to hot, and you don`t want to stretch or strip the plug threads in the head...
You are right. The oil gives about 10PSI more. The cold engine is about 125/130PSI as I posted yesterday. But I don't think 5 revolutions will get my gauge to peak. I didn't count, it was about 2 seconds.
Good reminder about torque on the plug. Somebody warned me in the thread before.
Now I have a shorter torque wrench to easily do this.
Is there a nominal "spec"? I have been using a socket tube and a screw driver
