Sounds like that happened today, the kids demanded it. And it stayed together so all is well.
Good job!
Thanks Sportster, Water lover, and all other members, visitors. I treated it as a teamwork. Even though we are probably 1000 miles apart
Cheers Team!:cheers:
Yes. cannot resist when kids are excited. This is the boating all about, at least to me. Yesterday we have one teenage, and 4 kids, and some adults. I went back and forward to switch people several times.
They all enjoyed and loved it. All good.
I checked the engine in the morning. Opened the Rave's, the blades have less black oil now (it was almost dripping in the break in) and same amount on both sides, no chocolate milk (wondering what was this thing in the first hour of break in?).
Looked into the Raves, the pistons are clean with a few scratching lines, not straight, probably from the installation. that black Teflon coating on the piston skirt has gone. Not sure why they put it there. Even I was testing the fit on the bench, the black coating already got scratched off a lot. I have never done this Rave check before, so I have no reference to compare, The rings are shiny, the pistons look "dry" to me, again I have no reference to the oil engine checked after running before adding oil.
Should I expect to see the piston is visually covered with oil and look "wet"?
Checked the spark plug, not oily wet, but with some small hard black particles (around 0.004" size) on the insulator and also a bigger piece on the "hook". Is it carbon residue?
Then I added oil, through the Rave, which I considered a better way, because you can see the piston
Did a compression test, PTO 130PSI, MAG 150PSI. A little surprised by the difference. But I always had a feeling that MAG side is "better" PTO side :-D.
Then cranked the engine a few seconds more for a couple of times, then did the test again. now PTO 135PSI, MAG 140PSI, test it again. both at around 140PSI.
Next time I should bring the compression tester on board, so that I can have some result from a hot engine.
I am thinking about getting a ski with 951 now. so that I can play a little more. That's the problem when you know a little about the things but don't totally understand, and getting dangerous. :willy_nilly:
I am watching for the skis for sell in the US now. Even it is for a project with fairly solid starting point.
Now I made the pressure gauge, I should change my pump cone pressure again. Last time I "couldn't" get the needle bearing pushed out and didn't change the shaft. and the shaft did have some grooves on it.
The only thing I changed last time is the thrust bearing and the washer.
I will order a new shaft. this time I will change the needle bearing, shaft, and seal, which is a real rebuilt.
