Bonmotwang
Do I need to worry about the set screws!
Do you mean the adjustment that allows the throttle to remain in the position you set it to so you can drive with both hands?
I wouldn't worry about it at all right now if that's the case, simple adjustment when back home on the trailer.
I meant low speed high speed screws. Do I know too lean too rich?
Golden rule, adjust them rich and then lean them back out the other way slowly with small adjustments followed by a period of operating the motor until you get it running right.
The high circuits call for closed on your's right? Remember the high side combines fuel from the low circuit as part of the total fuel input to the cylinder at higher rpm's so don't be afraid to try different settings with those low adjusters.
Try 1 3/4 and see what you get there you have more volume in your cylinder now so a little more fuel would seem appropriate.The manual says low 1.5 turn out. High close. I did as the manual says.
Do I need to open them more?
Tuning carbs is an art learned over time and LOTS of motors...
Yep, more of a caramel color than anything chocolate. Man, an old school Hershey's bar sounds good right about now with a cup of coffee...Water looks like milkshake when mixed with oil, dark oil looks like chocolate flavor but doesn't taste like chocolate.
Yes. Seems to be better. Transition is better. Just did a 5000RPM planing. Very strong and smooth. Should I try 1/4 on the high speed too?
Transition is good. Tried another 5000 planing. Very good. Revved to 6000rpm for 3 seconds. Oops:-D
While breaking in. I pull the throttle back. It sits at 1900RPM. Won't go back to 1500 as I set at the dock.
During breaking in the cylinder head and body are all cold. The exhaust pipe is hot. The water coming out of back is hot.
Cylinder heats up after shut off the engine.
There is some soft popping sound from the engine at 3000 Rpm. Every a few seconds.
2000 has no poping.
Sounds similar to light 4-stroking, if you meant a slight rich miss as opposed to a backfire pop.
