Guest_User
finished the battery switch today....
I`ve been wanting to remove the SeaDoo depth gauge that was never hooked up and replace it with a voltmeter. I finally got around to it. Had to modify the rubber trim ring flush so the gauge sits all the way in the hole.
There is no separate 12v key on power source unless you tap into the gauge power.
There is a 12V constant on power source, but that wouldn`t do any good keeping the gauge activated.
To simplify the wiring there was a short pig tail harness from the main to the fuel gauge. Reading the wire schematic showed me which wires to tie into. The wires are soldered in, and bullet connectors used with an added inline fuse to the gauge..
I understand the gauge will show slightly less volts than what is actually at the battery and it`s does just that. It is .5-.6 volts lower at the gauges than battery volts. I really just want it to monitor the charging system and that it is functioning correctly.
Also went with 2 HardLine hour meters that just use a single wire to trip the meters on... These are water proof, and I`ll see how they work in this location.
yes, and surprisingly matches the others fine. I tied into the fuel gauge lighting supply.
Just to reiterate what I posted in the transducer thread:
There was a change up due to some issues with the hawkeye depth gauge.
This is where to install a shoot thru transducer in a Challenger 1800 jet boat!
Success! The Hummingbird 610P depth gauge with XAP 9 20 shoot thru angled puck transducer works perfectly in this location.
On the dead rise just ahead of the ski locker.
I used rope caulk to act as a dam for the 2 part epoxy, formed it in a circle (after prepping and cleaning the hull) applied epoxy to the hull and transducer, secured with tape until it set up. 24 hours later done!
tested it out and with works up to max speed just fine! thank goodness...
note* and Doc Honda is correct, I contacted Hummingbird and I can get a new bezel and face plate for this gauge...
this is just a temporary bezel shown...
