Guest_User
shooot........The rivers were like Glass ...
shooot.
jealous. my boat is not cooperating with my first ever DIY attempt.
I've only been WOT on glass once...it was AYYYYYMAYYYYYZING.
Hey those spark plugs. Do I just unplug the rubber thingy, and unscrew them out? I'm going to put in new ones.
Yep, almost. Before the new plugs go back in you need to gap them. There should be a decal just below the hinges for the engine cover that will tell you exactly which plug your boat takes (NGK BR8ES) and also the gap (.021 or 0.55mm).
This morning in between the rain drops I cut in my recessed battery switch plate and installed it. Waiting for a few items and I`ll get back to that...
using an air saw with a scroll blade hanging upside down was interesting.:willy_nilly::lols:
and got an Oetiker Plier for the tool box! 1 of 2...![]()
mine is warm. one of these days I should tackle the leak isolation, and body repair tasks..... If the drain water is hot or warm, it`s coming from the exhaust system, or engine drain lines. also check the hoses at the exhaust outlets...
