Are you jetting the water box to?
Thanks I may buy something like that just to have in case I'd ever need it. Hopefully the 93 is sufficient.U can use Torco race fuel accelerator octane, the stuff can raise octane to 105,but 96 octane will be okay...
I use this stuff with great result, without deto, work very well, but is expensif.... http://www.torcousa.com/torco_product/un_acce.html
Check the blend chart
The best is avg /93 mix 50/50
Feeling like a plumber...![]()
Still waiting on a new main strainer. Just realized I accidentally ordered the 3/4 size. I did get the mounting bracket made for it.
Any specific reason to move it? Is the solenoid not strong enough to push water that far or just loses pressure?I would move the injection solenoid to the pipe instead of being on the strainer
A 2 stroke doesn't have constant positive pressure the exhaust wave actually creates a slight vacuum to pull in fresh fuel and air.Ok, I was just figuring that once the hose is filled the first time it will stay filled since the pipe cant suck the water out of the hose If the solenoid is closed. Kind of like putting your finger over a drinking straw and water stays in the straw.
For $2 in hose and moving fittings around its probably worth swapping though.
