This is the first time i've used transparent fuel lines and noticed that there is an air bubble up to the fuel filter.  It never seems to gst any bigger but just wondering if thats normal.  I dont see air in the line after the filter or after the external pump.
I've bypassed the fuel valve and gone directly to both on and Res and see the same thing. If its not normal i may need to swap the fuel baffle.
Just wondering if tjat could be causing a lean run on the high side and my bad plug readings.
