stovetop19
Ok, so I have a question for everyone who is familiar with doing the carb rebuilds and or premixing the fuel. I rebuilt the carbs myself, first time doing jetski carbs, but I used mikuni valves/seats and then the SBT gasket/diaphram kit. I used the stock size of 1.5mm seat. Stock spring and this seat size says around 17psi on the pop off according to the manual and both carbs are showing that.
Now, the boat fires right up from a cold start and idles really well, and runs great at all throttle openings.
but when I go to shut it off after its been warmed up, its hard to start, i have to hold the throttle wide open and hold the starter button for about 5 seconds and then itll start to fire but i have to keep it WOT for another 5-10 sec before it'll rev up and clear up, then it runs well again.
let it cool down and it fires right up no problem.
Does this sound like like maybe a carb issue or maybe did i get to much oil in the premix, I was shooting for 50:1 premix with xps synthetic, but I ended up putting just a little bit more oil than that (for the break in)
Any help would be much appreciated!!
