Thank you, I posted a desperate thread but 15 percent off for JULY4 right now to at Meguires direct.comIf the ski is old and was sitting replace the wear ring or it will typically blow apart shortly.
Manual calls for final torque of 19 foot pounds for cylinder head 717? Is manual correct? Manual only calls for 518 on cylinder sleeve o ring, is that correct also? Thank youI wouldn't as it is too easy to pack it into the ring groove and cause a ring to stick.
Running it hard with the correct oil and fuel should clean them up pretty good. You could even run some Yamaha powervalve cleaner if you are really worried about it.
But I personally don't like fuel additives in 2-strokes.
