1995hx
kudos on the find 1995hx! thats a damn nice ski! :thumbsup:
lovin' the modded HX as well
thanks juicyjay they are great skis its always a blast to build them from just a hull
The carbs are true bored flame arresters spec 1 hard jetted solas xo prop.
Sent from my C771 using Tapatalk 2
Hey guys can someone link me a worx intake grate I can't find one that will fit my xp thanks
the limited storage space in the X4 drives me crazy
Spim do you run the air baffle? Perhaps an under seat storage? Or in front of the tank?
There is one good reason to use a baffle....when water comes in thru the air intakes that the water is directed to the bottom of the hull.
It also quiets the engine noise going out the other direction.
It also delivers the incoming air to the bottom of the hull. I'm no marine engineer but I've noticed that the blower hoses on boats purposely do the same thing. This must better rid the area of any fumes.
is this the x4 thread? or has it been taken over by ugly ol hx's?? anyhoo if it still is the x4 thread can someone shed some light on what years were actual x4s?? so far in this thread there was conflicting info, is a 94 xp the original hull or was it the 95 xp?? i have a 95 spx which was the same as a 94 xp and i was under the impression it was not an x4, i just want the facts set straight once and for all, thank you
i looked at the model guide and the last year of the sp was the white/purple in 98, i didnt see a red/white, was the 98 sp an x4 and if so were any other sp' s x4s?
and on a side note i bet those hxs are a blast to ride especially with a 787 but im pretty sure seadoo r&d was going thru its awkward teenage stage![]()
whats everyone's thoughts about replacing the stock water control valve with a jetworks flow control valve and a separate line for the stinger?
It would keep the water box dryer at low speeds, supposedly making a faster holeshot :drool5:
