i got my xp out this past weekend, since dad got hurt i've been pulling 18-20 hour days, and saterday i said screw work its 85 degrees and i'm hitting the water!!
How is your dad doing? You said he got pretty busted up in that ATV crash a couple weeks ago.
Good for you.
I was going to go out last Sat... but the east coast hurricane hit land early, and left Pitt overcast, and a little cool.
he did. he was in the icu for a week, then they got him off the ventalator, a reg hospital room for a week, now he's in the rehab center and has come down with nomoania in both lungs.
Hey, does anyone know where I can get a Spec II pipe? I just got my carbs, MSD ignition and high compression head recently. Can't wait to see how it'll all play together![]()
So this may be a stupid ? but I would rather be safe then sorry, So this is the correct hydro turf set I need for my 1998 spx Right? it doesn't say Spx but xp which I take are the same patterns?
http://pwcmuscle.com/index.php?main_page=product_info&products_id=172
At what point do I start running higher octance fuels (higher than premium pump gas)? Is that a factor of the compression ratio, RPM, horsepower, all of the above? Is it something that can be judged by plug color? I'm going to put some mods on my XP and don't want to have to run racing fuel, will a Spec I pipe with ECWI, 41mm Mikuni Racing carbs, 185lbs compression and MSD ignition be too much for 93 Octane?
its all about compression. don't quote me on this but i believe anything over 165-170lbs you'll need to switch to race fuel.
