The X4 Thread
155 pump installed on 96 xp! Still some tinkering to do.
Laughing with you! Bitch work on pump fit. Telling you , run the 95 pump extension. Gives you aluminum to work with for taper mod fit. The set back pump turn those boat so aggressive for handling and its not for a novice. The SBT 95 xpl driveshaft is 20% bigger and holds up. To do over, I would run stock 96 pump. Validate engine alignment critically. Imhop
Sent from my SM-G920V using Tapatalk
Not familiar with 95 pump extension. Would you mind increasing my knowledge?
Got the billet rave caps from [MENTION=74959]Seadoodoc[/MENTION]
Oh geez 500! Those are a one off $300 set of caps. Hope they work well for you. Im done with those little 800 mtrs! (:
X4 will do that. Only ski worth all the headache of owning a performance 2 stroke
Sent from my SCH-I545 using Tapatalk
Impressive. Think im starting to get it. Essentially had to add material to eliminate gap between the wear ring and pump shoe ring. Im finding the same result on my build. (If im following correctly)
You got it bud! Grinding 8mm and gaining 8mm sucked. No you wanna double it? Yikes. Dont forget our 200 hp SS race boats stepped dwn to 148mm pumps for performace. Mibunkering built two of these conversions, he felt 155 made no difference vs stock. 148 skat is improvement.
I understand. I just didn't have a 148 skat laying around and wanted to use what I already had... also not very keen on modifying an expensive skat pump that I would not be able to sell in the future if I decided not to use it as it would only be for this exact application. Thanks for the insight!
I have an extra spacer setup off a 95 xp800 that had a messed up hull it's the plastic one not the aluminum off the 720 model. If you need it.
Im not sure what brand billet gas caps you guys are looking for but i emailed this guy and here is his response...
We have a few,
wcwerks@pacbell.net
Watercraft Werks
760 432 9900
wcwerks pacbell net
www hydroturf biz
www watercraftwerks com
I sent him this link when looking on his site:
http://www.watercraftwerks.com/p938/Sea-Doo-Billet-Gas-Cap-Black/product_info.html
THey do have them he is checking quanity. trying to see if he will sell them as a lot for a discount
