Here is a good, not to expensive, sorta needed maintance that should be done, possible every couple of years, is changing your fuel filters -- (2 strainers ) .... IN tank filters, just by removing your fuel pump assy, by removing your glove box compartment (4 retainers) comes right out, and there is fuel pump module, remove all retaining nuts, main fuel line, vent line, and wiring connector, then remove pump assy,
and take off bottom plate, then you have 2 fuel stainers (they are called) -- (advanced auto parts sells them ) 1 - part # fs242 -- approx 15.00 - 2 - part # fs220 -- approx 10.00 ---- also, if you want to change the bosch fuel pump at this point, they also have the original bosch fuel pump and part # is 20770241 -- approx price is 93.00, and then, take and remove all the fuel in tank, wipe clean with a shop towel, and re-assemble --
**** this is our fuel system repairs (along with 2 fuel injectors) , there is no problems with gray fuel lines, and carb overhauls, etc ****
and DONT put any fuel inj cleaner, etc in the fuel, (just clean 87 octane is sufficient)
