lswaffield
You rock... thank you!
You have to prep that rub rail like no ones business.I use lacquer thinner. I actually removed the rub rail from my HX to paint it, your boat I probably wouldn't with your arm. You can twist the rub rail 360 degrees and the paint will not flake off. The other thing you can do is use Frog tape, it has edgeblock technology where once water-based latex touches it the edge seals. So if you put it on, just take a damp sponge and quickly run it down the edge of the tape so it will seal to the fiberglass. Then paint, and remove.
My daughter continued the theme from last year where she would scream at me if I went much over minimum planing speed. Seems she is convinced that the engine is going to blow up at any moment, and going faster is going to make it happen.![]()
In regards to the kids, I had a 5 year old that would do the same, he would get a little freaked out if I went to fast. Until one day I put him between my legs and explained the controls and said he could drive, that way he had control of how fast he wanted to go. After about 3 minutes of him driving he was going faster then he ever let me go..........problem solved. Give it a try, it worked for me.
If your battery goes from 12.5v to 12 or even 11, I wouldn't say it's not holding charge. Not holding charge is when they go below 10v, but climb back up to 12 when load is off. The starter problem sounds like a bad bendix. They're pretty cheap on ebay and not hard to replace. You don't even have to open up the starter body to change, if I remember correctly.
Correct. It may also spin, but the bendix doesn't move out to engage the gearsHmmm. The bendix is the gear that extends to mesh with the flywheel, right?
Am I correct the symptom would be that I push the starter button and hear the starter spin, but the motor doesn't turn over.
Once you check the battery, take a set of jumper cables and attach the ground post of the battery directly to the starter (to test if you have a good ground). If it doesn't spin, rebuild the starter; if it does, it is a bad ground. If you are real flexible, and use a little black tape on the end of the jumper cable, you can also connect to the positive post on the battery and hit the post where the red wire connects to the starter to see if it spins. (FYI, do this with your MPEM disconnected; battery switch off. If you hit anything grounded, you will get a good shower of sparks)The current symptom is that sometimes when I push the start button I hear the starter solenoid click, but nothing else. No starter motor spinning, no engine spinning.
I'm thinking that means that either:
a) the starter isn't getting enough juice to spin
b) the starter is getting enough juice, but is failing
I spent a few hours on very HOT day last year following the wiring diagram and testing every part of the circuit, and didn't find anything obviously wrong. I wish I would have taken good notes though, as my memory is not 100% on all aspects of what I did and what I found.
I'll take the battery to the parts store tomorrow and have it tested to see if it is the culprit.
If it is not the battery, then I'll work through the starting circuit with the voltmeter and actually TAKE NOTES this time.![]()
Just saw one 1996 Challenger sale for parts with trailer for $1200. If I have more space I probably will go negotiate a better price and take on a project too![]()
Seems pretty high for a parts boat. Might be ok if the computer is good, but risky at $1200, IMHO.
I pretty much got mine free, after i sold the paddle boat that i bought with it and have
$3200 in it already.![]()
Thanks. That doesn't make sense knowing how much you have put in.
There are 2004 models around for 5000 to 6000.
Nice scare away list. Lol
In case it interests anyone, here is the breakdown of expenses on the Challenger project. I'm sure I've missed a few little things.
Total $3,227.10
Item Cost
boat, trailer, peddle boat $400.00
trailer tires, straps $185.49
Engine rebuild $949.00
sale of peddle boat -$250.00
hatch hinges $19.00
ball valve scupper $13.87
jet pump w/Skat impeller $240.00
impeller boot $8.00
5-way switch panel for helm $34.08
spark plugs $15.00
thread locker $13.26
fuse holder $5.33
buffing pads $21.74
air buffer $27.00
Trailer tail light assembly $14.00
battery tray $16.00
telescoping paddle $21.00
state boat registration - 3 year $60.00
fuses $5.00
carb rebuild kit $104.00
oil filter $11.00
pump hex nut $2.50
fuel filter element $20.00
G2 fuel filter $6.00
stereo & speakers $57.24
stereo cover $17.77
stereo antenna $6.28
depth finder $80.00
cup holder $3.00
blacktip traction mats $198.00
neoprene pump seal $7.00
upholstery kit $340.00
hour meter $14.00
sealants, hose pinchers, threadlockers $71.15
aluminum pump hose fitting $5.00
cyl head temp sensor $15.00
buffing kit $37.00
2x rechargeable battery/jump packs $19.00
locktite purple $7.06
spark plug tester $10.00
compression gauge $40.00
super siphon hose $15.00
4 x 5 gal gas cans $68.00
more spark plugs $26.00
UPS engine pickup charges x5 $62.50
rub rail insert $83.22
bilge blower $30.89
hatch & trailer sea doo stickers $12.35
trailer winch strap $11.44
registration stickers $6.99
side hull, transom & helm hatch stickers $41.94
tygon oil lines billed to GTX project alignment tool billed to GTX project
