Goingtobeapilot
Hello everybody. I'm new to the forum and so far I like what I see!
Anyways I just purchased a 1996 sea-doo gsx. The first thing I did was pull it into the garage and let it thaw out for a few days. After that I pulled the battery and charged it. I also changed the "beeper" due to the fact that it wasn't working. And where I believe my problem lies: I cleaned my rave valves... Sooo the valves were pretty bad and I decided to replace a few parts in them. Well when I put them back on I didn't realize that I hadn't tightened one of the valves completely...
So today I started her up for the first time. She needed some motivation to start (probably due to the fact that it was the first start of the season). I ran it for about 10 seconds and shut it off, let it cool down, then ran it again. I knew instantly what I did when I pulled the seat off and saw the oil rolling down under the valve. But I also noticed an extreme amount of fumes in the compartment. I turned on my flash light and you could literally see the beam of the light due to the smoke/fumes.
So my question is: Would the small gap from the rave valve being loose cause this? If not, is it possible that I just flooded the engine that bad? Or even better yet is this normal? And also what else should I check if none of these are the problem?
