I'm sorry I don't come here more often. I just read this whole thread and on the first page, I would have told you that you cannot use an OEM impeller boot on a Skat-Trak impeller. You need one from Scat-Trak. Also, I ALWAYS pressure test the pump at 10 psi and about 1 in 30 fail this test. It will tell you if you pinched the o-ring upon installation. It also checks the integrity of the seal.
^^^^^^^^^^^^^^Ok sounds good. I think I’m going to ride it the remainder of the season then pull the pump over the winter. Right now it seems as though the impeller and shaft aren’t bad. I think the toughest part is going to be removing the pump though. The previous person glued that thing on there like there was no tomorrow. It’s not going to be fun.
