JeremyD615
Here’s the dilemma... You may be able to use the same shaft and you may not. It depends on how significantly they modified the driveshaft when they swapped it to the carrier bearing. Normally, you will just use some sandpaper to knock the sharp corner down where the retaining clip would go on the carbon ring setup. If they just did some mild clean up here, then you may be fine. If they went to town with the sandpaper, that retaining clip may not be trustworthy once you go back to the CR setup... You’ll just have to look and see what kind of shape it’s in...
