Thanks, I know what you’re saying but I just don’t see how. There’s only one side of the rubber part that can go into the impeller. But the plastic part can not go over the other side. Also, the circumstance of the opening on the plastic part is larger than the lip on the shaft so it can move freely up the shaft.
The only way, I can see, that the plastic part can fit over the rubber boot is how I have it assembled but this is clearly wrong because it’s too long and the boot gets squashed after install.
So, to be clear, are you saying that I slide the plastic piece onto the shaft past the lip. Then, take the ribbed surface of the boot and insert that into the impeller then reassemble. Once assembled I should see some way that the plastic part can affix over the large rubber end? It doesn’t seem physically possible but if something changes after install I’ll give it a go! I guess the plastic could press against the large end but there’s nothing to hold it there.
Looking at the diagrams the boot shown is my shorter than what I received. But it has the same part number.
Thanks
